fourwheelinj1
Recently bought a T350 battery lift at auction and everything seems to work fine except the lowering the boom function. When you operate any of the functions you hear the electric motor run. The problem is when you hit the boom lower switch nothing happens. No noise at all. If the boom is low to the ground and you hold the switch it will lower super slowly but no motor engagement. Today I raised the boom up high using ground controls and it would not lower at all. I had to use the manual emergency lowering handle to get it down. Same results from ground controls or basket. No noise no warning trouble lights just does nothing.
