JLG N35 very slow forward/reverse
Discussion in 'Tool Carriers' started by fruitportcat, Jul 20, 2017.
  1. fruitportcat
    fruitportcat New Member
    Jul 20, 2017
    2
    michigan
    Hello, new to the forum.-----My boss recently purchase by auction a used JLG B35 lift. We did not see this unit perform b4 purchase. When it arrived batteries were dead, installed 6 new batteries and started to test. Forward and reverse or very slow-the manual says it will go 2.5 mph, probably can only get .5 if that, also is very weak, will hardly go over a bump. Do have manual but not very helpfull in trouble shooting. Checked voltage to contactors in motor area, getting 48 v to and across contactors. But motor supply voltage out of controller is only 3-4 volts at motor terminals. There is no led malfunction lights lit not is the single "ok" light lit. Sounds like a bad controller but would like some advice.--Thanks
  2. laycobeau
    laycobeau Well-Known Member
    Jul 8, 2013
    57
    Lead electronic technician
    Tulsa Ok. beau.bowlan@lei-corp.com
    what's feeds the controller a joy stick? brand and part # on control and maybe I can help
  3. fruitportcat
    Jul 20, 2017
    2
    michigan
    Yes it has a joystick-forward & reverse on joystick and a 2 way steering switch. The controller is a JLG au1830n. But in my search I just found the tilt indicator bulb burnt out-replace bulb and the indicator is on. Tried to test tilt switch-3 wire bubble level type- but is different than the ones on our Economy scissor lifts that I am used to. Any Ideas on how the tilt switch works and or can be tested. I am waiting on the actual service manual to arrive that was ordered, all I have now is just a operators/parts manual.
  4. laycobeau
    Jul 8, 2013
    57
    Not sure but most JLG wire 27 is + 24 is ground an wire 5 is voltage out 0 volts when level
    goes to tilt relay
  5. southernman13
    southernman13 Senior Member
    May 13, 2008
    341
    Retired
    Florida,Ga,Tn
    Sounds like it's in creep. Are the book sections out of time? Or u may have a stuck limit switch
