I hope someone can help me with this.
I was running all the hydraulics stop to stop,
and the basket would not rotate all the way to the right.
And now it is stuck full right.
I can hear the motor click when the switch is selected,
both for left and right. And it seems to move about an inch
when left switch is selected. So I'm hoping it's just stuck or air in the line
or fixable.
I topped off the hydraulic fluid and it's just above the bottom fill line.
I greased both fittings at the pivot points.
I put a tow line on the basket and brought it tight with some force,
and then tried the switch.
Nothing has helped so far.
Is there a way to manually center the hydraulic motor?
I think I'm going to have to break a line loose which I wanted to avoid.
So can this be fixed without opening up the hydraulics?
Thanks in advance.
or fixable.
Thanks in advance.
