lee95
I am having drive issues when you first start off it will drive perfectly and you might go 10' or maybe 100'. And it will stop instantly and will not move either direction all other boom functions still work fine. When I move the handle into drive position you can hear the motor pulling and it sounds like maybe the oil is going thru a bypass. Wiggling the wires by hand will not fix it but if I rotate the basket and or swing the boom back and forth it will start driving again and work fine for a bit and then does it again. I suspect the brakes are locking on as a couple of times it tries to move but is real jerky and then it triggers the bypass and stops. I assume there is an electric solenoid that sends oil to release the brakes but I don't know which one it would be. I do have the manuals but they aren't very clear at least to me.
This has the 425 Ford Engine. Any ideas of how to troubleshoot this would be greatly appreciated.
Thank You.
Thank You.
