rookieatbest
I have a JLG 40E that I repaired two hydraulic lines and now have the lower two booms out of synchronization. I bleed the lines prior to moving and when the bottom two booms elevate they go up, but when lowering the middle boom doesn't move in the down position. I tried the recommended manual lowering procedure by turning the descent knob counterclockwise and pumping the emergency handle. It was extremely hard to pump up and down. I then turned the descent knob clockwise and the pumping was much easier and the upper boom began to lower. I tried this as a test to see if the pumping of the lower and upper booms were different. Of note the upper boom works perfectly fine and I lowered it. The middle and lower booms go up, but when lowering only the lower boom goes down and the middle boom will "stick" in position and not lower. I know this wasn't the right thing to do, but I slowly unscrewed the plug on the block of the holding valve cartridge on the middle cylinder just enough to let it drip into a collection container. The middle boom slowly lowered over the course of the next 4 hours all the way to its resting position.
Before I attempt to elevate it again, does anyone suspect that the holding valve cartridge is bad? or some other issue that I can troubleshoot.
thanks!
thanks!
