If the function works when pushing the button, the next step is centering that valve.
Centering
On the proportional valve bank, on the bottom side, you will find three 1/2" lock nuts around Allen head screws in the middle of 3 big hex's, one on each section.
Loosen the lock nut on the swing section
With the engine running on ground control, turn the screw in until the tone of the hydraulics changes, signaling the start of that function.
Turn the screw in the other direction until the tone of the hydraulics changes again, counting the number of turns of the screw from one to the other.
Turn the screw to the half way point between the two, and lock it down.
