I'm going into work now I will check, any help you can give me will be appreciated! Thanks crashWhat fuel line did he change and how much oil is in the crankcase?
he replaced hydraulic hose going to the middle of the electronic throttle positioner. There was 2 gallons of oil missing from motor, and he has no muffler hooked up to exhaust system, also there was thick resin drops under the turbo, he was running the machine for a short time with no exhaust system and was going inside of the engine compartment. He also told me after I dropped the oil that the machine does not run quick, it's slow when Excavating. I'm thinking we have a turbo problem. Any help you can give me would really help, this is the first time I have worked on heavy equipment ,most of my diesel work has been on boats. Thank you.!!!!! CrashI'm going into work now I will check, any help you can give me will be appreciated! Thanks crash
From this description it sounds like a turbo issue. Any oil residue in the turbo piping?[/QUOT
I will check tomorrow, there was a gummy oil residue under tubo and around exhaust pipe, could he have caused the turbo failure, not having any exhaust hooked up? Plus it's just a straight pipe going out then up no muffler, I cut a angle on the end of the pipe today to keep rain water out.
