Knivens894
A 490E approaching 7,000 hrs in service was working, but running toward the hot side, when it suddenly lost power and will not spool up under load. Pressure relief valves were removed checked and replaced without any issues being found. The hydraulic tank filters were removed and inspected with no issues being found. Pilot filter was removed and replaced, again with no issues being found. The pilot pump was pressure tested and found to meet specifications. Pressure testing the main pump revealed 3,850 PSI (out of specifications). The angle sensor setting was checked and is out of specification, unable to meet the voltage using the slots provided for the bolts. A new angle sensor was installed, but again, was not adjustable to specifications using the bolt slots in the angle sensor. Does this mean it has had a main pump internal failure, or could there be some other issue(s) that need to be checked first?
