After consulting with my John Deere dealer they were kind enough to print out the pages I needed from this machine's diagnosis manual TM1504. The lower computer is the PCV controller, while the upper is the engine controller. The PCV controller is readable by the user with the aid of one jumper wire and no additional computer is required. The PCV controller was showing 5 different codes. The first was the angle sensor, which I checked to find it was producing a signal of 4.85 V. When it was installed it was producing 4.40 +- 0.03V as the repair manual directed and would not go back to 4.40V so I replaced it with a new sensor. The new sensor was set at 4.40V as the manual directed. The stalling characteristics of the machine were not changed.
The next code related to the pump control solenoid valves, so I checked them with an Ohm meter to find one fairly open at 1,850 Ohms (unload valve) while the other was much lower. I am ordering a new pump control solenoid tomorrow and will install it upon receipt. My question now is: Are all the codes read valid, or would one or two out of range sensors cause other codes to be displayed? If anyone knows I would appreciate the information. The machine has been out of service a week already for this problem. If I must address all the displayed codes, I want to get on with it to put the machine back to work.
Thanks!
