Yep, sheared key or broken crankshaft snout. If it's just the key and things are not yet wallowed out too bad, pretty easy. Pull the hydraulic pump and drive shaft, one bolt in the middle of the pulley, pull it out, replace the key, put it back. Or cuss and cry because the crank is too worn to keep the pulley tight in place.
