JD 200lc travel speed servo
Creekside Tom
Have a John Deere 200lc excavator that wont shift to rabbit. I have 400psi at both motor servos. The manual doesnt show the right pressure for that . Need to know if that is enough pressure to shift the servo. Thanks all
Creekside Tom
Yes the switch did change from 0 to 400. I have since found the end of servo broken on one side and replaced motor witch now shifts fine. I will be removing the other motor to see what is wrong with it. Yet i still don't know what the correct pressure should be.
