Thank you for visiting HeavyEquipmentForums.com! Our objective is to provide industry professionals a place to gather to exchange questions, answers and ideas. We welcome you to register using the "Register" icon at the top of the page.
We'd appreciate any help you can offer in spreading the word of our new site. The more members that join, the bigger resource for all to enjoy.
Thank you!
Have a John Deere 200lc excavator that wont shift to rabbit. I have 400psi at both motor servos. The manual doesnt show the right pressure for that . Need to know if that is enough pressure to shift the servo. Thanks all
Yes the switch did change from 0 to 400. I have since found the end of servo broken on one side and replaced motor witch now shifts fine. I will be removing the other motor to see what is wrong with it. Yet i still don't know what the correct pressure should be.
I found it in a military the pressure spec is 425psi
Here is the link for the book It is put together by military so it is a bit different than Deere put the specs are the same.
it will take a bit to download. http://www.liberatedmanuals.com/TM-5-3805-280-24-1.pdf
