jcb 135
Moonlite
Texas
i have a jcb 135 skid steer that was running and died. its not getting power to the fuel solenoid, also noticed that when cranking the display shows 0 rpms. i have checked fuses and relays. any suggestions?596A4F2D-9EA7-4E50-832E-4F9584FE7D88.jpeg
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
If your stuck in the bush/field, hot wire the solenoid straight from the battery..
& inorder to keep from smoking the starter, loosen the steel lines AT THE INJECTORS and crank until u get fuel & no bubbles then tighten.
