Acoals
What I don't understand is the ground pressure is the same loaded, unloaded, or overloaded
I don't follow this ground pressure logic. I don't know what the contact area is for an 18 wheeler, but let me just guess so we have a number; 8x8 contact patch per tire: 64 sq in. Multiply that by 18: 1152 sq in. So we have an empty rig that weighs 35,000lb, that is about 30lb per sq in. Load this truck to 80,000lb, now we are at 69lbs per sq in. I suppose the contact patch may increase some when you load the tires, but it isn't going to increase by 60%.
When the dump truck sinks into the mud, you dump the load and drive out. The ruts going out are way shallower than the ones going in.
