in search of a used mini
fullphase
Vancouver Island, Canada
Hey there,
Finally found a site that I can bounce some ideas off of! ya!
New to the site, and the world of excavators, I bought a piece of property and would like to have a machine to do some work with. So many questions! I guess first of all, i am thinking of size, I rented a JD60 and that seemed to be ideal for what I need, but been pulled to the JD, bobcat, hitachi.....in the 7500lb range. Not sure if i will be kicking my self if I go that small....????
My lot is all sand and gravel, the majority of trees are cleared, so thinking i will be ok......
Also, a guy I know is selling a Hitachi ex75UR excavator (grey market). I was telling a couple of dealers about it and they said to stay away as it might be hard to get parts and you never know what your are getting. I still tempted, because it is in my price range (30k Canadien) looks in good shape and the meter is only reading 200hrs (i guessing that is incorrect though). It has a mechanical thumb not hydraulic, and only comes with one bucket and no quick connect.
Also, looking at a bobcat E35 former rental unit with 3000hrs.
Any thoughts comments are greatly appreciated.
thanks
Mike
Billrog
Armstrong, British Columbia
band mill , backhoe and dump truck
Mike I recently bought a mini & when looking for a few mons. noticed there was a good selection on the Island compared to the mainland. Personally I wouldn't be scare of the Hitachi if it was in good shape I'm sure there are plenty of parts available.
007
Ex Rental with those hours would not be the most desirable.
There is no question having a machine is great but what sort of jobs are you thinking of.
No question the larger machine makes light work of large trees and dams etx.
But if your just landscaping irrigation post holes and the like the big machines are a pain.
With my place i hire a big machine for the large jobs and have a small mini for the smaller work.
I find its less fuel, cheaper to repair, move it with trailer.
We use the little one every where like a tractor but the bigger machines make to much of a mess of the grass every where they go.
No machine is perfect for all so you have to think of what it will be doing most of the time.
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
When shelling out that kinda money, you really don't want to limit your options.. 1 bucket & no Quick connects sounds awful limited to me. ??
Billrog
I agree with thepumpguy I shopped until I got a machine with a hydraulic thumb and a few buckets 2600 hrs. just under 8,000 # because it's big enough to suit my needs.
fullphase
all great ideas and thoughts, just what i need.....keep any ideas coming! I am kinda looking at spending 25-30k on a machine, i guess that is a limiting factor, but is it unreasonable to find a decent machine, with thumb, couple of buckets, and a full cab for that kind of $$? Can anyone comment on this machine on craigslist? It has been for sale for quite awhile, looks good, price is good, but it isn't selling.....kinda has me wondering why it not selling.
https://vancouver.craigslist.ca/rds/hvo/d/1998-bobcat-337-excavator/6427898582.html
i have texted with the seller, he said he did a bunch of work to it, paint, new decals.......
thoughts.....??
Billrog
I looked at that machine when I was shopping Mike looks nice a clean not bashed up for the age. Only reason I didn't peruse it I was looking for rubber tracks and 0 tail swing for my purpose . My experience with excavators is limited so I really have no sound advice.
code54
Hurricane WV
I have a Kubota KX91 - around 7500lbs for home use. Works great. Taken down some larger trees (24" oaks), and use it all the time for moving logs, trenching, etc. No complaints at all. Think really had about a quick detach and a thumb. I have 3 buckets, QD bracket for lifting and switch them around all the time. Takes a minutes so it is easy to have the correct size bucket whenever you need it. I also bought used but went with low hr (232hr) and spent about 32k US. The previous owner worked it along rebar and tore the track sides up but they are still fine. (Have a new set waiting when needed)
Diggin-Fool
Michigan
I have a Kubota U35 with 12", 24" toothed buckets. I followed dealer recommendation of 30" grading bucket. I suppose anything bigger would be too much stress?
suladas
That bobcat above is pretty pricey. If you're working in any sort of residential, tight areas, etc that machine wouldn't be any good. On a small machine zero swing is a must, and steel tracks are a pain. I really like the 6 ton size, big enough to load trucks and move it's share of dirt, but small enough to fit in and dig in tight areas. A 8 ton is just too big for so many things, and any smaller then 6 ton can't dig much. The boom swing on the Takeuchi is an awesome design too which really helps in tight areas.
For a price reference I bought my 2006 Takeuchi TB153FR 3 years ago with 2,900 hours 2 buckets and hydraulic thumb for $39,000, i'm just east of you in Alberta.
Huband1
Vancouver Island
Teacher
I am looking for a similar size machine as well. I have a buddy that has recommended I try to stay under 2000 hrs for a mini ex. He figures with much more hours I could be into significant amounts of repair. What were the red flags on the Kubota kx 121? Too many hours? The thumb looks like it was repaired kinda funny, the machine looks very clean, but I suppose the photos could have been taken when the machine was newer.
Alan
suladas
Alan
The thumb being patched together is a red flag. The other is the picture of transporting, the machine is tied down and bet anything they transported it with the second bucket like that, that is a terrible way to do so and so illegal. Also the tying down of machine is awful. The rear has holes on the outside of undercarriage to tie down by. May seem small, but things like that are generally decent indicators on how a machine is operated and maintained. If you can't be bothered or don't have the experience to tie down equipment properly, will you know how to operate or maintain it? A lot of those pictures were when it was new, look at how the bucket has virtually all it's paint, it's no indication on how good it looks now.
I bought mine with 2900 hours i'm at 3500 hours now the only big repair was an electrical issue, not really related to hours but more age. I am currently at the point where the bucket pins have quite a bit of play and should be replaced. Other then that still no concerns. I think 3000 hours or less is a better guide, however depends more on your budget. It's very easy to check condition of pins though. I am a firm believer of spending a bit more to get a newer/less hour machine to avoid repairs, but at the same time need to consider how much use it will see.
farmboy555
KY
Owner Operator
I have a 6000lb & 12000lb Yanmar’s both purchased off Craigslist 1800 & 1400 hrs thousands less than you would find them on a lot somewhere. I save over $3k on sales tax by private sale
Decided what you want and keep your eyes open. Took me 9 months to get one and 3 to find the last one
fullphase
Thanks Bill, good to know. Another issue with me buying on the mainland is getting it transported to the island....I am sure that is not a small bill.
What would be the best way.....call transport company i guess.....?
Billrog
It would be good to get a few quotes maybe 1 from Hot Shot. If you purchase a machine less that 10,000 # perhaps 8,000# you could consider renting a trailer and picking it up yourself.
fullphase
Again thanks for all the responses guys......a few more questions:
Outside of running steel tracks on pavement or concrete, what are the other advantages disadvantages to rubber vs. steel tracks?
What about renting your machine out while you are not using it. Is that something you would suggest, or stay away from. thinking about things like insurance, damage/repair costs....but also potential income to pay the thing off!
Thanks in advance!
TrentNz
New Zealand
Steel tracks last longer than rubber.
Most people prefer steel but limited to rubber due to working on surfaces that need to be kept in good condition.
I wouldnt be afraid of getting a machine between 5000-10000 hrs as long as maintained well.
Bought our kubota with just under 4000 hrs and had no issues so far at 5500 hrs - still a very capable front line machine.
That allowed us to recently buy a low hr machine
