kpowl
Left over parts for T4, T5 or TD5 for sale. Includes:
(2) Top idler assemblies for 5 roller tracks
(10) Roller assemblies
(3) Track adjusters (2 have broken springs)
635096r1 - Clutch Pedal
635102R1 - Clutch Shaft
635150R91 - Propeller Shaft Assembly
Engine Pressure Plate - Useable, no broken springs
(2) 635089R1 - Clutch Housing Spacers
635008r1 - Cover Assembly - 1 corner broken, seals up fine
636223R1 & 636224R1 - L and R steering sticks
635269R1 & 635270R3 - L and R Foot Plates
Steering Clutch Release Shaft Links - (2) new & (2) used
635010R11 - Right Steering Clutch Housing Cover Assembly
(2) Complete Steering Clutch Assemblies - Parts or Rebuild
635376R1 - Steering Clutch Drive Hub - Used
Set of used Steering Clutch Disc - Could be cleaned and Used
635387R1 - Steering Clutch Release Shaft - Left (NOS)
635377R1 - Steering Clutch Release Bearing Sleeve
635062R21 - Bearing Assembly - Final Drive Pinion
(2) - 635390R1 - Bevel Gear & Hub Spline Shaft
(2) 635072R1 - Pinion Thrust Washer
635272R91 - Drawbar Support - Has Had Brackets Welded to it
704395R96 - PTO Shield - Excellent
635414R21 - Heat Shield Assembly
635275R11 - Drawbar Pivot Bracket
Battery Tray Assembly
635261R1 - Rear Fender Bracket (NOS)
635063R1 - 25T Track Drive Sprocket - Plenty of wear left
635700R1 - Hydraulic Filter - Good Used
635649R92 - Heavy Duty Crankcase Guard
Starter Motor - Delco Remy Model 1108060
635574R1 - Track Adjuster Wrench (NOS)
(3) 306239R1 - Master Links (NOS)
(1) 306240R1 - Master Link (NOS)
(16) 12" Track Shoes - Good
(62) 10" Track Shoes - Most have had Cracks Repaired at Bolt Holes;
8 Simmel Track Links - Lots of Wear Left
Hood for Gas Engine - Not Perfect but very Good
(2) Complete Sets of Track Chains - Both are very useable. 1 set has had pins welded in for some reason (not factory). The other set has the original pins pressed in.
I am located in central Indiana. $2000.00 for everything. I can send additional pictures.
