Colorado Digger
i am with a mini ex or skiddie with a hammer. break it up but not down to the concrete. then put a head shaker on the mini and ou'la . simple.
What is on the pad to hit? anything? pipe's, etc.?
breaking up pack ice.
I suppose you'd have to ask yourself if you're happy with the performance of the backhoes.
How much traffic do these pads see?
Why let the ice build up to 18"?
Some salt goes a long ways.
mini ex with hammer was my first thought.....what putting frost pick on the mini ex?
If the concrete is thick enough and been in place long enough i'd just choose the right time of day............. you should be able to slide a ''knife'' under the sheet and break it up in chunks........ chemicals and heat work but i can't believe they are efficient as sliding a piece of steel along the cement.................. providing there is just a little water interface there.
Hmm, so break the slab loose from the concrete, calcium or mag chloride is a lot heavier than water or ice. Can you drill down close to the slab with say a 1 inch auger every foot or two and pour a couple cupfuls of mag or calcium down each hole. That should make a little heat and start to creep between the ice and the slab, loosening the bond between the two. Both of those chemicals work down below zero but calcium is more in your neighborhood of -25F
Purely from a desk perspective, perhaps you could just bore holes on the uphill side and keep filling them with calcium and let it creep toward the drain, a couple random holes might show how far the creep has progressed. Might have to put some water in the holes to get the fluid volume up a bit.
