Thanks. Engine was rebuild but still had a knocking sound and the engine was dropped down again. Now I am told the crankshaft is dead. I don't know if it's a long or short block. I will find out from my mechanic and get back to you. However the serial number is 72V04667 and manufactured in 1983.The early 140G had a PC engine and in 1980 went to DI. I have both at my ranch that I don't need. Just need to know if you need a short block, long block, or complete engine takeout from a 140G. What happened to your engine?
What is wrong with your engine? Those 3306 engines are pretty easy to overhaul if no major parts are bad.
To help anyone who may have a lead on an engine a full S/N of your engine would be very helpful, there have been a few variations on the 3306 over the years.
The terms "long/short block" usually would refer to whether the replacement come with a head and maybe other components like flywheel housing and front cover. I'm sure just about every one has a different definition of what would be included in a "long block".Thanks. Engine was rebuild but still had a knocking sound and the engine was dropped down again. Now I am told the crankshaft is dead. I don't know if it's a long or short block. I will find out from my mechanic and get back to you. However the serial number is 72V04667 and manufactured in 1983.
