I started the 310 last month to keep everything lubricated but when I tried a few weeks later I could not get the starter to run. I took the starter to the shop and had it rebuilt. It was rusty inside so it needed the work. I installed it and had the same problem. I charged the battery, and checked the starter battery connection, I had 13.2 volts. When I checked it while turning the ignition the voltage went to 0. I then tried to jump between the bat. terminal and the S terminal and nothing happened. I hear a click sometimes but no cranking. Could this be a bad ground? someone said the engine may be frozen, that water may have entered the cylinders. When I have the chance I will pull it and jump it straight from the battery to see what will happen. The previous owner cut a lot of wires I would like to fond a wiring diagram.
Thanks
Nick
Thanks
Nick
