I got a FREE forklift, but need help indentifying what model it is.....
msllc
MID-ATLANTIC = VA
This baby was given to me for free as a "throw-in" when I bought some equipment last year. I found a data plate, but it NOT legible. Some FOOL painted over it, like a big dumbie!! Can anyone help me identify this baby???
msllc
MID-ATLANTIC = VA
If I remember correctly, the data plate is aluminum & the info was screen printed on that plate, the some body painted over it. I seriously doubt that it was stamped. If it was, that paint is on there very, very thick. It is a shame that it wasn't taped over before they painted the machine.
It started up & ran wonderful. It was set outside for about 3 years, before I got it. I'm trying to get it together, to try to sell it. It needs some brake, tires, battery & alternator work to be put back in service. I think that the master cylinder is seized up. I'm having to guess that the wheel cylinders might be as well = GO FIGURE!!
bteigrob
Houston, TX
is the "M" painted on there or was that a factory result. Because that could mean Mitsubishi which would make it a sister of Caterpillar in terms of lift trucks.
OFF
Alberta, Canada
HD Mechanic
Looks to me like some vintage of Caterpillar V50D OR V50E
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
I just looked at mine.. at work.. T50C.. w/a 1404 engine.. don't hold me to that.. just might lead you in the right direction..
msllc
MID-ATLANTIC = VA
Thanks guys for all of the replies.
I know this is an older machine. She ran great from the day I got it off the roll-back tow truck. It sat all that time, so she still has great spirit to carry onward. She's just begging to be used everyday again!! Where on the mast / frame can I look? It seems there is absolutely no standard for where they can or should be. I'd be glad to take the time to make a brand new data plate, as long as I knew what it was.
msllc
MID-ATLANTIC = VA
The large "M" was added to the machine, over top of the yellow paint. I went ahead & carefully removed that mess. I think it was used as a way to identify it for use by a certain shift or department.
