On my Case 480c I noticed each time I pulled the plug to put some hydraulic oil in the reservoir, it would puff air out under a slight pressure. I saw in the manual that is has a breather that needs to be cleaned out once in awhile, it has a access plug on top of the hood area beside the fuel tank filler.
I finally got around to prying up the plug and taking the breather vent assembly out. Of course it puffed again. I took it apart, it has a sintered brass filter on the bottom, but on the top part it has a spring and a washer. It seems to work like a check valve, letting air in if it needs it, but not letting air out. Everything was clear, the check assembly is why it's puffing air.
Does anyone know the theory behind this? As you lose fluid you need to let air in to prevent a vacuum in the tanks, but why not let air out also?
