Hello to everyone in the forum!
Due to the fact that I am too poor to buy a nice skidder at the moment, I bought an old L-785 that had been sitting for 2+ years due to an engine issue and was involved in a good old fashioned barn fire too (big mistake!)... I’ve got the machine running and the hydraulic oil was very very milky, so I drained all 22 gallons and refilled. It is still a bit cloudy, but doesn’t look nearly as bad as it was. Now when I raise the boom cylinders the charge pressure warning light comes on and it gets worse as the machine warms up. I replaced the warning sensor (preset at 50psi) and it appears it is a real low pressure condition as it is still alarming. I installed a pressure gauge on the bucket cylinder and when the stroke is max’ed out the pressure can reach 2,200psi and you can hear the control valve begin to bypass. I took the gear pump apart and the gears looked perfect, although there was probably .010” of wear in one side of the aluminum casing.
Could this be enough wear to cause a low flow condition in the pump? The machine is supposed to have around 2,500hrs on it, although I’ve come to trust nothing the seller told me about the condition of the machine at this point. I’m on the fence on if I should bite the bullet and buy a new $400 gear pump? The way my machine is designed, the gear pump feeds the control valve, fluid is then filtered, goes into a 110psi check valve, excess goes back to the sump while the constant 110psi fluid feeds the hydro drives (charge switch is located on the feed to the hydro drives). I would hate to install the gear pump and be back in the same spot again, but it would sure be sweet if that worked too! Any advice would be GREATLY GREATLY appreciated! I don’t have much experience with this type of equipment and thoughts/ideas would help!
Thanks A Lot!
Thanks A Lot!
