Looks like that flow divider is interaxle! The interwheel ones would have to be pilot operated, otherwise if the would be full time - they would tear up tires really quick!
I see now! I missed another (gear type ) flow divider! Strangely enough spool type is on one line going to motors and gear type on the other line?!
Picture is not good, can’t read, without understanding of what is what I can only guess that gear type is “ differential lock” and spool type is regular differential ( gives more flow to the wheel that travels on outside/longer radius, and looks like the diagram you posted is for four wheel drive as well as four wheel turn machine, because motors connected in cross fashion, and there’s turn switching valves)
And the “motion control valve” switches from one mode ( flow divider ) to the other.
