How to hook up dozer hydraulic lines to a Bobcat skid steer??
swampdog
Just bought a HLT 86 inch dozer for the Bobcat skid steer. The HLT dozer is new - came in the metal crate. It has two hydraulic lines, both of which have male quick connect fittings - no female fitting. Is this an assembly error at the factory? Should one line have a female fitting? The Bobcat only has one female fitting - what to do with the other line???
Thanks for any help.
lumberjack
Columbus, MS
One should be male and one female. Did you buy it new for your machine? If so, I assume there's an error. If you bought it second hand, it's possible they configured it for another machine.
Is it just an angle blade or angle and tilt?
swampdog
It's an angle blade without tilt. I had another look at it and two two male fittings aren't the right style either for the Bobcat female on the machine. The male fittings have a round protruding ball-like center piece instead of the flat center piece needed for a Bobcat. Markings on the wrong male fittings are: LSQ-S4-04PF 1/2 BSP. Not sure what that would fit - maybe some non-Bobcat machine or a tractor? The dozer unit does have the correct skid steer quick attach mounting plate, so this is meant for a skid steer it seems.
swampdog
Here are pictures - the first picture is of the fittings that came with the dozer blade. The second picture is of the type of fitting that would fit into the Bobcat quick connects.
Still wondering whybobcat 2.jpgbobcat 1.jpg the dozer would have come with the wrong fittings??
crewchief888
NWI
very seldom i've found an aftermarket attachment that had the correct fittings on it...
:drinkup
Jonas302
mn
The fittings on your blade are pioneer type fittings they are on a zillion pieces of equipment the blade would fit right on my new holland exactly how it is the ones you need are flat face that is a newer style and considerably more expensive
bobcan
Cold but Sunny, Western Canada
Exactly TRUE, and why they are like 'Batteries once were in Electronics' and May Not Be Included _ That being said, as a Canadian, I can tell you to go to the local (if you have) Princess Auto Ltd. and look for them as 'Stucchi' flat-faced connectors.. mate with machine just perfectly for anything I have used, well made (seemingly) and often On Sale for half what other sellers want around here.. Likely get for $50/set you will need, I suspect.. and if you can wait/ want to stock up, I think were $35/set last I got.. Good Luck!!
http://www.princessauto.com/en/search?Dy=1&Nty=1&Ntt=Stucchi+Flat+
swampdog
Thanks for the explanations. We do have a Princess Auto and a Bobcat dealer a couple of hours away. Tried NAPA - they said that they don't have these fittings.
Another question for when I get the correct flat face fittings. Since both fittings on the dozer at the present time are the same, does that mean that it does not matter which line one hooks to the supply line and to the return line on the skid steer? I'm thinking that it does not matter, but could be wrong. One line on the dozer goes to the rear of the ram cylinder and the other line goes to the end of the ram cylinder nearest the ram.
willie59
Knoxville TN
Service Manager
Makes no difference with the blade, only with your preference of operating the thumb switch. Push the switch to make it go left, or push the switch to make it go right, whichever way it seems logical in your own mind to operate, fit up the male/female couplers on the hoses to accommodate your preference. :)
