2112
Cavalier, Condor 46
Has a ram to pivot the bucket to make level. It had a tiny drip that turned into a heavy leak where the rod exits the cylinder.
I am looking at the Ram mounting points from the outside, and I am unsure how to disengage the ram so I can get it repaired.
There appears to be two solid crossmember tubes. The smaller one toward the end has nothing near it so I assume press fit. The larger back round bar has a 1/4" set screw at the bottom of each side, but after taking them out, I don't see how they release anything.
The white bucket is to catch all the ATF leaking out of the boom.
Before I start trying to tap these out, any suggestions?
