Hello everyone, I had a perfect working ZX350 lc3 that got a hole in the A/C evap which is under the seat. Removed seat, rear partial shelf, uplugged many wires (after I marked them) replaced evap and put back together.
Problem, everything works except Hyd thumb close. This is located on R/S hand grip with two buttons. Left =open and Right = close. When I switched the plugs by my lower right elbow the Right was now = open. I think that that tells me that the button are OK.
There is a relay panel behing the seat with 4 blue relays. the two on the right (looking towards rear of machine) I think go to open/close buttons. When I push open does open) L relay clicks and all works great, when I push R/S button R relay clicks but no close. I am assuming that I have power to relay if it clicks???
Thought that the problem was then between wires going out of relay andand out of cab.
I was going to start looking "down the line outside of the cab but I still think its something in cab because it worked fine 4 hours earlier and only unplugged and replugged. Any thought would be appreciated, thanks!
