Hey Folks,
Thanks to all that answer these posts and make the rest of us look smart in front of the boss. We have an old CAT 950B wheel loader that is in good shape but recently it sporatically started to lose both forward and backwards power which we believe is somewhere in the transmission. It is all of a sudden, as if a transmission valve decided to stick or not function. When cold, it move great. Every once in a while, when hot, the motor pulls fine - plenty of RPMs and it sounds like lots of power - no skipping or missing - but the machine will not go uphill or over any type of road blockage such as a hole or a rock. Anything can stop its forward or reverse movement. When it happens, we can't even get it up on the low-boy for transport.
Being an X-automotive trany guy, two things come to mind here: 1.) transmission slippage; 2.) torque converter failure. I have sort of ruled out transmission slipage because the trany oil does not smell burnt at all. Also, it has been doing this for a while and my thought is that by now, the clutch packs would have been burnt up and not work at all. (By the way, it does this in all forward and reverse gears/speeds.) But, you let it cool down and the machine goes back to working normal. So, I have been thinking about the torque converter.
Can any one tell me if the torque converter in these CAT 950Bs have the ability to fail (not multiply torque) and then start working normally? I put a pressure gauge on the converter outlet pressure (Test Point D) and I am getting 55psi which is in line with the spec. I could really use some help here before I tear this trany out. Again, thanks to all for sharing their knowledge and experience!:scool
Chris
Chris
