jessedavid
Ok here's my problem. I was hired to replace a grease trap. 12.5 feet deep. where I live is in a severe drought but my pit keeps filling with water. Obviously there is a water leak somewhere leaching back into my ditch. how can I get the mud and rock in the bottom of this ditch to solidify so I can set a 12k pound grease trap on a solid base.
I've tried using 1.5" crusher run and it didn't work any help would be greatly appreciated I posted here because you guys/gals use big equipment and hopefully have had similar problem.
I have a city fire main 20-30 feet from my hole that I believe is where the problem is coming from
or I have a 8" private sewer main that is broken.
either way I need a solution. that doesn't involve finding the leak if possible.
can mixing lime in my ditch make it solid enough to compact?:Banghead:Banghead:Banghead
