dwall2181
Hello Friends,
Was out running the Case 580C yesterday and after taking a break I got one click of the starter then no crank thereafter.
Had good battery voltage and fuel. Noted the power wire circled in the attached picture to the starter has a break in the casing. After playing with the yellow wire a bit I could get a click of the starter but no crank. Plan to replace it.
Question is. Where is the starter solenoid? Seems like I’m just seeing a starter. Any tips to test currency to the starter? Also attaching pics to the back of the key. The push button start has not been used in the machine as I just usually turn the key over and it cranks. Appreciated any help to diagnose.
Thank you!
Thank you!
