I have a pesky little problem, its a suction leak someplace on my log splitter. When its running I see bubbles coming from the return line, its a home made aluminum tank, 25 gallon with two baffles built in, solid on the top and a handful, maby 10-12 of 2 inch holes on the bottom to help strain out the air bubbles.
I thought it was the hydraulic pump, Haldex/northern tool 28 gpm dual stage. I have a 2" suction line that goes through a suction side filter/screen and necks down to a 1 inch line to go into the pump, I suspected the pump as one of the 4 bolts broke off sometime, found it while checking torque, and the pressed in intake fitting came loose as well.
I put in 4 new bolts, knurled and red loctited the suction line in place after giving the pump a good cleaning. Still showing air bubbles! Crap! tighten all the clamps and put the A/C vaccum pump on the tank vent and sucked her down to 10 inches. Well the tank drain had a little bubble leak, squirted gear oil on it and it was silenced, I applied oil to every joint and coupling, no change in the air bubbles percolating into the return line, tightened all clamps 1/4 turn more, no change. Pulled the pump off while still plumbed and applied oil around the shaft seal, no change in the rate of bubbling, one bloop every two or three seconds. I'd have to kick the vac pump on every five minutes to keep the numbers near 10.
I'm perplexed unless the suction lines, 2008 4 wire are leaking in a way that they're not leaking oil but letting air in. I'm going to try blocking off parts of the system to see if I can narrow it down some.
