Have a 1994 pete with electrical issues
rioncrsn
south carolina
It cranks fine and all the lights work, but no electrical gauges work, ac , or jake brakes any ideas???? Thanks
Oxbow
Idaho
Were it me I would start my search at the backside of the starter switch and key switch and make sure that the accessory side of the switch is working. Next would be checking fuses and relays in the fuse box. I don't believe any of the pop out button breakers supply power to the dash, but if one of them is sticking out it won't take long to find out.
Good luck and hope it helps!
sl3406
United States
There is a fuse for accessories in the fuse panel behind the clutch pedal that powers the dash gauges. That would be where I would look first.
