cfherrman
Don't forget to look for the L
I have an older AMMCO 3/4" drive torque wrench that is similar but the center section pushes out and flips over to change direction. You pull a small detented pin out on the side and the ratchet section then drops out.And, some torque wrenches will not work for LH threads. On mine for LH, i take the ratchet head apart and reassemble the drive square out the other side. I could drill a hole in the opposite side of the detachable handle but it would be too easy to get it mixed up if someone else is helping me. This way, there’s no doubt about which way its set up
They remained in but will be replaced when tires are remounted. They don't usually leak or creep rust but these are many years old and very well could be original from 1987. Rims are all original to the truck and stamped 1987. They are "Budd" manufactured.Did you leave the valve stems in when you blasted? Will they bleed rust later?
