Hammer Issues
D5GDevo
Kentucky
Howdy everyone. I just resently purchased a Komatsu PC-160 LC with a NPK E-210A Hammer. I used the hammer for maybe 12 hrs and noticed that it was leaking hydraulic fluid out of the exhaust hole of the hammer, not extremely bad but enough to make me stop before something bad did happen. It was still operating as it should. I greased the hammer about every hour of operation with the tool in the vertical position. I am not familiar with the internal workings of a hammer, but I hear they can be very dangerous to work on. Anyone have any info would be greatly appreaciated.
Thanks in advance.
D5GDevo
willie59
Knoxville TN
Service Manager
I haven't worked on an NPK breaker before, but I've never seen an "exhaust hole" on a hydraulic breaker either. Could you post some pics of the suspect area?
D5GDevo
Kentucky
Ok lol. It may be just a vent hole but anyway it has fluid leaking out of it. I'll try to post a pic.
xr4ticlone
TEXAS
Trusted Adviser to the Construction World
My guess (I'm not a mechanic & not overly familiar with NPK) that shouldn't be open. It appears to have threads in it? Could be a place to put air for under water operation? A good hammer shouldn't be hard to fix.
NPK makes a decent hammer, my biggest beef is with their price of parts and repairs.
That said, if it's still working I would take it in and have it checked over. Meade or Erb look to be the only dealers in KY. I'd call and talk to both to see if they have a hammer specialist that just works on hammers. A surprising number of dealers are clueless on hammers, even ones who sell them.
D5GDevo
Kentucky
I check with my local dealer today and he said that fluid leaking out of that vent hole was a sign that the hammer needs servicing, 700.00 Seal kit. WOW. What can you do but order one and get it fixed. Hope it not out of my capabilties to repair.
mikebramel
milwaukee
Before you order it I would take it apart. Most of the time you're going to need hard parts also if you want to do a complete job. Before you take it apart, be aware of of the charge on the accumulator may cause things to move when you dissasemble
xr4ticlone
TEXAS
NPK makes a decent hammer, my biggest beef is with their price of parts and repairs. ;)
I've never rebuilt a hammer, but I know some are easier than others. NPK, from what I'm told, is NOT one of those easier to fix brands.
http://read.dmtmag.com/i/726012-september-2016/33?m4=
Page 35 + (Horrific title to great article on hammers)
MrElectric03
Northern Idaho
D5GDevo- The plug that is leaking is called a drain passage. It provides a tell tale when the upper seals have blown out which yours have. The hammers are not difficult to disassemble if you have a 1" impact to remove reinstall the tie rods and you will need to use a small port-a-power to remove the sleeves. The biggest thing is knowing what to look for on the internal parts and most people freak out seeing normal wear and will condemn a perfectly usable hammer.
Muffler Bearing
Colorful Colorado
Truck Mechanic
Good to know we've got a few guys on HEF building hammers, I just started on them 6 months ago, they are an odd creature indeed, not a lot of manuals or support out there and dozens of brands.
Tones
Ubique
I don't know anything about NPK hammers but a outfit I worked for many years ago ran Teledyne hammers. When they did a rebuild they replaced the 4 bolts that go down through the guts. They used a torque multiplyer to tighten, 1000ftlbs if I'm remembering correctly.
Loganj22
Salem va 24153
I've rebuilt hammers for 2 years now and HIGHLY recommend you don't use an impact on tie bolts. It will cause stress fractures that will eventually make the bolts break and they are really expensive. I usually put the lower housing in a press to hold it and use a multiplier (17:1) I think.. torque specs are important! And be careful taking apart any hammer bleed off your accumulators first just to be careful. They can have close to 1000 psi or more in them sometimes.
AzIron
Az
700 for a deal kits not a bad price the pistons are what gets expensive but if you tear it down replace the upper and lower bushings re seal the piston and the trigger. Sometimes the piston gets a little mushroomed where it hits the tool you can clean them up with a grinder
Also you don't want to use an impact on the main bolts npk makes a striking wrench for them to tighten them up
The hammers are really simple it just takes time to go through them keeping them clean and don't roll an o ring putting it back together
If you take care of those npk it will take care of you I have some that are 25 years old and only been rebuilt once
