1693TA
Pumped this tank down to sucking air and it performs well leaving just a little in the bottom. The fuel was transferred to my transfer tank in my pickup and I then pumped the fuel into the dozer tank which is now about five gallons shy of full.
With the tank now empty as I can make it with the pickup tube, I'll open another valve down low to drain off any accumulated water or sediment. This was used as a gravity tank and has another filter on the former output they used. After I know this tank is clean I'll remove this apparatus and install a ball valve to be used as a drain only. With a street elbow installed into the ball valve pointed downwards, it will be an easy drain setup should it be needed and not be a "knee knocker" hopefully.
