Grove rt 58
Tyler d4c
Salix Pa
Bought it thought it be nice for around the shop ill be posting up the repairs as they get done. Any idea how to lube the swing bearing. Bought a manual dont feel like waiting on it
crane operator
sw missouri
Should be two lines with zerks behind the boom raise and lower cylinders, or somewhere on that plate, that lead to the inner of the rotation bearing.
crane operator
sw missouri
Its possible that they are on the side of the upright frames, but the lines should run down to the inside of the bearing. If its dragging on swing, its probably the swing brake dragging, more likely than just the bearing being dry.
Tyler d4c
Salix Pa
The swing break disc is really shiny that very likely to be the problem the swing doesn't seem to be hard of turning of nothing just the occasional bit of noise out of it
