More off topic....as some of you know I am building a 2.5 million dollar press at work.Its a prototype and I am not allowed to talk about it much..I will just say its going to roll/press 4x8 sheets of steel into something else.I am doing all the fabrication (pretty much done)as well as all the assembly/fitting and I am doing all the hydrolics on it as well.Some of the parts exceed 30,000 lbs..I will pre assemble it at work,take it apart and then ship it to the site where I will reassemble it.I will also look after the machine once it is running.We are doing the feed tables as well.
This is a pic of some wheels I just assembled.I did 35 of them.Thats 70 bearings at roughly $1200 a bearing.Wheels are 12" diam.Outer diam was ground not lathe turned..
Pic of motor and gear box base.Top plate is 2" material,base is 13' feet long.There are 2 of them .Each gets a 300HP electric motor..
