big builder
I found this online... are these accurate power numbers? Will this engine honestly make 202 hp @ 2500 rpm's. If so it should hav enough power for the job. I noticed that max torque is 445@ 1500 rpms. Is this a more important number than max horsepower?
Detroit Diesel 6v-53N Engine - Typical Industrial Specification - With N50 Injectors
6v-53N POWER at sea level
RPM 1500 2000 2500 2800
Horse Power SAE 134 175 202 216
Power Kw 100 130 151 161
Torque Ft lbs 445 432 410 395
Torque Nm 603 586 556 336
Fuel Consumption 22 28 31 34
Max Toque Ft lbs 445 @ 1500 RPM
Max Torque Nm 603 @ 1500 RPM
Physical Characteristics Detroit Diesel 6v-53N
Weight 1485 lbs 674 kgs
Length 39" 991 mm
Width 40" 1016 mm
Height 37" 940 mm
Compression Ratio 21:1
Displacement 318 Cu Inches 5211 ml
Bore 3.875 inches 98.425 mm
Stroke 4.50 inches 114.30 mm
Torque specifications Detroit Diesel 6v-53N Engine
Torques (Non standard) Bolt Size Ft Lbs Nm
Accessory pulley nut ¾ NF 125 170
Air box cover 3/8 NC 15 20
Big Ends 3/8 NF 45 61
Cam and Balance-shaft nuts 1 1/8 NF 300 407
Cam follower guide bolts ¼NC 15 20
Crank end bolt 1" NF 290 393
* Cylinder head 5/8 NC 180 244
Flywheel Housing Bolts 3/8 NF 30 41
Fuel Connectors 3/8 NF 25 34
Fuel Line Nuts 3/8 NF 15 20
Governor to flywheel housing 5/16 NC 12 16
Idler gear hub bolts 3/8 NC 40 54
Injector clamp bolts 3/8 NC 25 34
* Mains 9/16 NC 125 170
Rocker arm bracket bolts 7/16 NC 55 75
Sump bolts 5/16 NC 10 14
* Flywheel bolts ½ NF 50 + 90-120 ° 68 + 90-120 °
* Apply 'Copper-Slip' or equivalent
Common Settings Detroit Diesel 6v-53N
Set Inches mm
Injectors (N45 & N50) 1.460 37.10
Valves (cold) 0.026 0.70
Standard Sizes and useful clearances Detroit Diesel 6v-53N
Part Min inches Max inches Limits ins Min mm Max mm Limits mm
Con Rod - ID Small End Bush 1.3760 1.3765 . 34.95 34.96 .
Con Rod - Length centre to centre 8.7990 8.8010 . 223.49 223.55 .
Crankshaft end float 0.0040 0.0160 . 0.10 0.41 .
Crankshaft Big end Std Diameter 2.7490 2.7500 . 69.82 69.85 .
Crankshaft Mains Std Diameter 3.4990 3.5000 . 88.87 88.90 .
Cyl liner - flange below block 0.0465 0.0500 . 1.18 1.27 .
Cyl Liner - flange below block variation 0.0000 0.0020 . 0.00 0.05 .
Cyl Liner - ID 3.8750 3.8767 . 98.43 98.47 .
Piston skirt diameter 3.8699 3.8721 . 98.30 98.35 .
Ring gap - compression rings 0.0200 0.0360 0.0600 0.51 0.91 1.52
Ring gap - oil rings 0.0100 0.0250 0.0440 0.25 0.64 1.12
Tune up & useful information 53N Detroit Diesel engines
Item Condition
Altitude deration 2.5% for every 300 m or 1000 ft
Cooling System - engine capacity 3.30 litres
Cooling System - radiator capacity 7.10 litres
Firing Order 1L-3R-3L-2R-2L-1R (viewed from rear)
Oil consumption normal 71 to 203 ml per hour
Oil pan capacity average 16 litres
Speed full load max Most common at 2500 rpm
Speed no load max Most common at 2750 rpm
Speed at idle commonly at 680 rpm
Operating Conditions 53N series engines
Item Condition
Compression (sea level) New parts - average 40 bar
Compression (sea level) New parts - min 36 bar
Fuel Pressure @ 1500 RPM 3 bar
Oil Pressure - normal operation 3.5 bar
Oil Pressure - idle 0.8 bar
Oil Temperature - sump 90-113°C
Water Temperature 77-91°C
Length 39" 991 mm
Width 40" 1016 mm
Height 37" 940 mm
Set Inches mm
Item Condition
Item Condition
