Globe 50 ton ground bearing question
mpd310
I have a 1992 Globe 50 ton Detach neck ground bearing trailer. Globe cant give me any specs on the trailer at all need info on the main cylinder. size and stroke any info on the trailer helpful
thanks in advance
Will Musser
Globe really doesn't keep info like that. They never did on the Globe trailer I had and broke anyway. You might try calling Witzco because the trailers they built then were for all intents and purposes a Witzco. The best Chance though is to just grab your tapemeasure and go measure it. Look on the Surplus Center website and find one that is meets what you are looking for. Ive had to do that before.
anything built 2005 or before, we have no records of. The previous owner of the company took EVERYTHING. i do have some cylinders left over from the previous owner and i have been able to help some of his customers out. If you can give me the measurements, im sure i can locate you a cylinder! :)
