I have here a Genie Z60/34 boom lift serial number Z60-3551 with 2370 hours on it. That somedays the swing is good in either directions .Other days it so slow in either directions.Anyone have any ideas.
Wow where's the genie guru. I need help too.I,m new here too. I,m having problems with my Z60. I, intermitently, loose all my joystick functions( all three joysticks) The toggle switches all still work. To get the unit working again, I shut the machine down and restart it, and it works. I,m not getting any codes on the board, and I have tried to recalibrate all the joysticks. I checked the ground connection on the side of the box, and it,s ok. Not sure where to look now.
need serious help-my genie 2008 Z60/34 serial # Z6008-9237 has cracked all 4 existing drive hubs and 1 new for a total of 5 drive hubs, the casting cracks I'll assume for over pressuring
check vlv was also installed as repair shop said he found problem but didn't, this machine now sits till i find a real solution, i'm not buying another drive hub until i know whats making the cast crack and leak!
please any help will be much appreciated-
