livewire1
Hope some one can help i bought this machine in 2002 factory recon by genie thats they said. Machine is a 2000. Hyd outriggers, blue boards were installed under warranty in 2003. I have replaced the overlays, base in 1-2015 platform last year seems like i am replacing overlays every couple years starting to getting really expensive machine is stored in side i am a electrical contractor . Not a lot of people use it low hrs, last year i was having problems with out outriggers going down and not going up located that problem white amp plug on control box was missing locking collar so pins were not fully engaging. Replaced amp plug and new pins worked fine after this fix Seem like every other time is one or other overlays is bad shows a code . Now the out riggers will operate down pushing extend and one rigger at a time not auto and none will retract at all it is not showing any codes. I took The lower control cover off and unhooked plug of overlay and ohm metered all the overlay switches it checked out. Controls acted up a little before this but started working . My next step is double checking the plugs and pins . genie over engineered this machine is the new control box worth it if is a clean machine. Not worth much not running .
