Thanks for chiming in. I know you guys are experts on these engines. I simply can’t find any threads on this particular application. At least it’s been a learning experience. I did long hard thinking at one point with a close solution.,
Level the block on the engine stand with a torpedo level.
Throw pushrods in #1, and get the cam at tdc in between exhaust and intake, used the level again (sitting on top of pushrods.
Put the level on the cam gear going vertical. Marked a line on top and bottom of cam gear.
Now throw in the crank at tdc #1 meshing the gears carefully.
Now as long as the dot on the crank lines up with the cam (cam being vertical level with custom lines)and they are both at TDC, I can now spin the crank 360 decrees and be now at TDC Comp Stroke.... right?
I know it’s confusing, but that’s all I got.
