Alaska Dan
- Joined
- Sep 22, 2009
- Messages
- 58
- Location
- Wasilla
- Occupation
- I make a line of holsters and other gun related pr
My 1980 TD8-E is acting up. It has eratic RPM's and acts like it is running out of fuel. There is plenty in the tank. It will run at half throttle but revs up then almost dies.
Things I have done:
Checked tank for debris - it is clean
Cleaned air filters with air hose
Changed both fuel filters and filled each before installing new
Traced fuel line back to tank looking for signs of air/fuel leaks - none fouind
Loosened injectors at the pump - good flow
When I took the Final fuel filter off, the "O" ring was broke. A frienbd and I both thought that was the problem but it had no effect.
I'm at a loss..
Dan
Things I have done:
I'm at a loss..
Dan
