No, I'd start with the pump back to the tank. Unless there's a rubber line that feels soft or funny.
Does your tank have a drain? Drain some fuel out before you start it up every time until it comes clean with not a speck in it. The state of the primary filter/strainer should give you an idea of the amount of junk in the fuel tank. It's also possible for something like a plastic seal from the a bottle of fuel additive to get caught in the wrong spot and cause issues. Sometimes draining and rinsing the tank is the only way to figure it out, "suckbucket" will do the job if there's no drain. The fuel is fine most likely, just let it settle and put it right back in. If there's a screen on the intake in the tank, then that saves some trouble with little bits plugging up the line, but a screen will plug with other stuff too.
If you want to diagnose the system rather than cleaning it, move that gauge around to see where it's plugged. 5-10 inches of mercury (HG) is too much in my mind. If the gauge goes from 0-30" then it's mercury.
