Here's the rub as I have experienced it. In TierIII we had the introduction of high pressure rail fuel injection with either cooled EGR or external EGR of some sort. The High pressure rail intro ran at lower comp ratio, to minimize dependence on EGR . During this phase in , some manufacturers already began to see the effects, the metallurgy wasn't quite up to snuff. Some blocks began to erode at liner counter-bores, some heads failed at unusual locations.
TierIVi introduced regen or aftertreatment. More reliance on EGR almost exclusively cooled EGR to control NOx . Big bores used a more proven DOC/DPF regen while there was no standard for mid range engines between 6 & 9 liters . Tier IVf became less dependent on EGR but more on SCR. They found that by running hotter and harder , they by nature, produced less particulate matter(PM). This caused an increase in NOx production, but now with more accurately controlled EGR and more efficient cooling of the EGR added with the SCR introduction in the downstream flow, Nox was brought to near 0 levels. The higher combustion/exhaust temps while already reducing PM also contributed towards getting the DOC up to temp without the use of burners or additional ignition systems.
TierIVf was a huge step forward, TierIVi was a major set back but a stepping stone. The other thing that the mid range engines saw was the introduction of air throttle blades at the intake . This could help control EGR and cold weather heat up, by forcing the engine to work harder for that air.
Until the metallurgy catches up to the technology, we are gonna have problems with premature component failure. Add to that the higher pressures in the injection system ( injectors, pumps, regulators etc) with the ultra low sulfur fuel with no lubricity, and dependent on where you are and what kinda knucklehead purchases your fuel , you might be pushing corn oil through that 18,000 psi injector orifice. How long is that poor thing gonna last.
If they could maintain the operating systems , remove the emissions derate, they'd have some real powerhouse engines in much smaller packages with incredibly low fuel consumption.
Regen should not cause a derate. It has no damaging effect on the operating system. Just because a sensor is out of range, it's gonna shut down your whole production line. That's just there by gov't interference dictating that if any thing is tweaked or out of range or defeated in any way, it'll shut ya down. (not cool)
And lastly, how come only civilized countries have to put up with this. No China, No India, Some parts of Africa, Some parts of south America. Machines auctioned off in the states to out of country buyers can have emissions removed and software reprogrammed to run without, by the manufacturer!!! . They get the power, the fuel savings and the simplicity, we have to deal with BS.
Sorry for the long winded rant, but emissions are a bit of a sore subject with me. Machines today run so much cleaner and more efficient, I don't feel we need to keep going on the backs of those who work for a better tomorrow. We need to withdraw from the GHG treaties In My Opinion.
