northmanlogging
Hello again,
Looking to fabricate some log guarding fer my excavator, I could buy... but I can also weld so
What I'm lookin for is attachment points, hows every one else doing it etc, Front side is a no brainer, but behind the cap is kind of a mystery. I'm not a big fan of hackin up sheet metal, cause well... then its hacked, so if I can leave as much as possible factory the better.
A lot of what I see on the interweb is canadian stuff, with lots of heavy guarding on the side, which is all well and good, but I'd like to be able to lock the door open, and that heavy guarding gets in the way.
I pretty much work alone most of the time, and I hop in and out of the cab a lot, so dicking with the door every time is a real pain.
Also most folks use square tubing for this kind of project, and I probably will, but I'm considering using heavy wall angle so it fits closer to the cab, less junk to get hung up on. (like 1/4"-1/2" wall 3"x3" ish) if I go with tubing it will be 3/16-1/4 wall 2" square... Undecided as to what the front is going to look like, probably vertical bars, with some expanded steel on the lower to protect the lower glass, unless I can get my grubby paws on some shaker screens.
