This is a new thread but it is a continuation of trying to debug this engine problem that started with a previous thread about the LRG 425 not starting. I am able to get the engine to start reliably now, but it shuts down after running for 35 seconds. I've started the engine 7-8 times and it always shuts down after 35 seconds. Here is what I know:
This engine is used in a 25kW generator. It has a DSE 703 controller.
- It doesn't appear to be the DSE controller telling the engine to stop. When looking at the DSE 703 indicator lights when the engine stops, I notice that right after the engine stops the battery light goes on for about one second and then turns off. Right when the batter light turns off, the oil pressure light comes on and stays on (which I think it should because at this point the engine has stopped and there is no oil pressure). The interesting thing is that it appears that the DSE 703 controller still has the gas valve opened when this condition occurs. I have to hit the off button on the 703 controller to turn off the gas valve - this also clears the low oil pressure light.
- The engine oil pressure appears good. I have an oil pressure gauge and it shows 50psi right up until the engine stops.
