daman
If talking the rubber flex lines that goes from the valve body(controls) to the start of the hard lines(boom) it's easily really...
remove the backhoe from the tractor that frees up a lot of space in the back to work in then the key is removing lines but you need to remove one line to get to another the worse part of the job just make sure you do not cross lines,no special wrench is needed I've done it many times on my 4500 with standard tools tho a PITA these lines are very do able.
