FordFortyFiveHundred
Hi folks,
My 1971 Ford 4500 would not shut off at the end of the day. I went to shut off the engine, and it kept running, pretty rough. Usually it will idle down to 500 rpm, then I pull the fuel cutoff. It stayed at about 800 rpm, and did not respond to the cutoff. I got of the tractor and verified the cutoff was pulled to the rear of the tractor, to no effect. At this point it was running pretty rough, with lots of black smoke. It this increased rpm on its own, to about 1400 rpm. I cut off the fuel at the tank, and used the hydraulics to put a load on the engine. It then finally died.
I am afraid to start it again, without know if it can runaway. Is this possible? I am thinking this is an IP issue, as it seems to effect 1-2 cylinders, the exhaust is black not blue, and killing the fuel disabled the engine.
I thought this may have happened yesterday, but is shut down before I got off the tractor to check. I then restarted it, and it ran fine.
Any thoughts? Something easy to check, or just send out the IP for rebuild? The injectors are new when I installed the new head.
Thanks,
Skip
Thanks,
Skip
