I'm working on the 955C 12A-03563.
I pulled engine out and removed the wet clutches pressure plates and flywheel everything looks good so far but the flywheel has quit the wear on the ring-gear - 1/4" ground. I know on other types of equipment you can turn the ring-gear over and reuse them would that be possible on this ring-gear setup?
