Alaska Dan
- Joined
- Sep 22, 2009
- Messages
- 58
- Location
- Wasilla
- Occupation
- I make a line of holsters and other gun related pr
This has been such a hassle that I don't think I could explain it without it sounding like complaining. So I'm going to the bottom line.
After receiving a horible fluid report I took the filter to my mechanic as well as the service manager at NC Machine. There were a few very small filings in the paper and both said it was nothing to worry about. The guy at the lab said. "That isn't bad". Doug at NC Machine told me to run it until it is warm, then let it idel for about 5 minutes. If it stays around 25lbs it's fine. I just did that and it stays up around 35 to 40. He suggested I change oil and check it again. He thought it would be fine.
Regarding the trans noise, he said I have gears with grooves straight across instead of at an angle and that will cause more noise. Also the weight of the fluids can cause that.
I'm going to change all fluids and check things again after about 50 hours..
Dan
Dan
